OS-T: 5070 Fatigue Optimization of a Torque Control Arm
In this tutorial you will perform a free-shape fatigue optimization on a torque control
arm. The objective of this optimization is to increase the fatigue life of the control arm by
changing the geometry of the model.
Before you begin, copy the file(s) used in this tutorial to your
working directory.
The torque control arm is loaded by brake force and vertical force. Two load time histories
acquired for 279 seconds with 1HZ are applied. The material of the control arm is Steel,
whose S-N curve.Figure 1. Model of Control Arm for Fatigue Optimization Figure 2. Load Time Histories for Vertical Force Figure 3. Load Time Histories for Braking Force Figure 4. S-N Curve of Steel
Launch HyperMesh and Set the OptiStruct User Profile
Launch HyperMesh.
The User Profile dialog opens.
Select OptiStruct and click
OK.
This loads the user profile. It includes the appropriate template, macro
menu, and import reader, paring down the functionality of HyperMesh to what is relevant for generating models for
OptiStruct.
Set Up the Model
Launch the Process Manager and Import the Model
Launching the Process Manager.
From the menu bar,
click Tools > Fatigue Process > Create New.
The Create New
Session dialog opens.
In the New Session Name field, enter a
session name.
In the Working Folder field, navigate to
your working directory.
Click Create.
A new file to save the instance of the
currently loaded fatigue process template is
created.
The Process Manager opens.
Import the model.
In the panel area, set the Model File type to
OptiStruct.
In the Model file path field, click and open the
tarm_fatigue.fem file you saved to your working
directory.
Click Import.
Figure 5.
The control arm model is loaded. This model includes a whole definition of two
static subcases, elements sets, and material static properties, and so on.
Click Apply.
Create a Fatigue Subcase
The Fatigue Subcase task should be selected in the Process Manager.
In the panel area, Create new fatigue subcase field, enter
fatsub.
Click Create.
In the Select existing fatigue subcase field, select the newly created fatigue
subcase, fatsub.
fatsub is selected as the active fatigue subcase. Definitions in the
following processes (analysis parameters, fatigue elements and properties,
loading sequences, and so on) will be for this subcase.Figure 6.
Click Apply.
The current definitions are saved.
Apply Fatigue Analysis Parameters
The Analysis Parameters task should be selected in the Process Manager.
Set Analysis type to S-N.
Set Stress combination method to Abs. Max.
Principal.
Set Mean stress correction to GOODMAN.
Set FEA stress unit to MPA.
Set Rainflow type to LOAD.
In the Gate field, enter 0.0.
In the Certainty of survival field, enter 0.5.
Click Apply.
The current definitions are saved.Figure 7.
Apply Fatigue Elements and Materials
The Elements and Materials task should be selected in the Process Manager.
In the panel area, click Add.
The Material Data dialog opens.
Set Element entity type to Property-PSHELL.
Set Element entity name to shells.
In the Ultimate tensile strength (UTS) field, enter
1800.
Set Input method to Estimate From UTS.
Click to view the SN curve definition, then click
Close.
The SN Method description dialog introduces how to
generate the SN material parameter.
Set the Material type to Steel, then click
Estimate.
All the data for SN curve definition are automatically
estimated.
Click Plot SN Curve to show the SN curve, then click
Close.
Set Layer of stress results in shell elements to TOP and
BOTTOM.
Set Surface finish to No Finish.
Set Surface treatment to No Treatment.
Leave the field after Fatigue strength reduction factor blank.
Click Save to save the definition of the SN data for the
selected elements.
Click Apply.
The current definitions are saved.Figure 8.
Apply Load-Time History
The Loading Information task should be selected in the Process
Manager.
In the Process Manager, under Loading Information, select
Load-Time History.
Create the load-time history, hist_y.
In the panel area, click Add by
File.
The Load Time
History dialog opens.Figure 9.
In the Load-time history name field, enter
hist_y.
Set Load-time history type to
CSV.
In the Select load-time history file field,
click and open the
tarm_loadY.csv file.
Click Import.
Click Plot L-T to show
the load-time history.
Click Save to write the
new load-time history into HyperMesh database.
Close the Load Time History dialog.
Create another load-time history, hist_x, by importing the file
tarm_loadX.csv.
Click Apply.
Load Sequences Definition
The Loading Sequence task should be selected in the Process Manager.In this step, one event consisting of two load time history is created, in other words, the
linear superposition of the stress caused by the two load time history is requested
during analysis. Using this event, one load sequence is constructed.
Add a loading definition.
The Loading Definition dialog opens.Figure 10.
Set Select static loadcase to loadx.
Set Select load-time history to hist_x.
In the Scale field, enter 1.0.
Select Create new, then enter
Event1.
Click Save.
Add another loading definition.
Click Add.
opens.
Set Select static loadcase to loady.
Set Select load-time history to hist_y.
Select Existing, then select
Event1.
Click Save.
Click Apply.
The fatigue problem set up is now complete.Figure 11.
Set Up the Optimization
Create Free-shape Design Variables
From the Analysis page, click the optimization
panel.
Click the free shape panel.
Create the design variable, upper.
Select the create subpanel.
In the desvar= field, enter upper.
Click nodes > by sets.
Select node set upper, then click
select.
Click create.
Update the parameters for the design variable, upper.
Select the parameters subpanel.
Select options.
In the nsmooth= field, enter 10.
In the mvfactor= field, enter 0.25.
Click update.
Repeat steps 3 and 4 to create a new design variable named
lower with the node set
lower.
Click return to exit the panel.
Create Optimization Responses
From the Analysis page, click optimization.
Click Responses.
Create the volume response, which defines the volume fraction of the design
space.
In the responses= field, enter volume.
Below response type, select volume.
Set regional selection to total and no
regionid.
Click create.
Create the fatigue response.
In the response= field, enter life.
Set the response type to fatigue.
Using the props selector, select shells.
Toggle to no regionid.
Under no regionid, select life.
Click create.
Click return to go back to the Optimization panel.
Create Design Constraints
Click the dconstraints panel.
In the constraint= field, enter con_life.
Click response = and select life.
Check the box next to lower bound, then enter
2.0E4.
Using the loadsteps selector, select fatsub.
Click create.
Define the Objective Function
Click the objective panel.
Verify that min is selected.
Click response and select Volume.
Click create.
Click return twice to exit the Optimization panel.
Define the SHAPE Card
Only displacement and stress results are available in the _s#.h3d file
by default. To obtain analysis results (displacement/stress/temperature) on top of a
shape change that was applied to the model in HyperView, a
SHAPE card needs to be defined.
From the Analysis page, click the control cards panel.
In the Card Image dialog, click
SHAPE.
Set FORMAT to H3D.
Set TYPE to ALL.
Set OPTION to ALL.
Click return twice to go back to the main menu.
Run the Optimization
The Submit Analysis task should be selected in the Process Manager.
In the panel area, save .fem file as field, .
In the Select File dialog, select the directory in which
to save the file, and save the file as tarm_fatigue_opti.fem.
Set Run options to optimization.
Click Submit.
Figure 12.
OptiStruct runs the fatigue optimization.
If the job was successful, new results files can be seen in the directory where the
OptiStruct model file was written. The default files
written to your directory are:
tarm_fatigue_opti.0.4.fat
An ASCII format file which contains
fatigue results of each fatigue subcase in iteration step.
tarm_fatigue_opti_s4.h3d
Hyper 3D binary results file, with both static analysis results and
fatigue free-shape optimization results.
tarm_fatigue_opti.out
OptiStruct output file containing specific
information on the file set up, the set up of your fatigue problem,
compute time information, etc. Review this file for warnings and
errors.
tarm_fatigue_opti.stat
Summary of analysis process, providing CPU information for each step
during analysis/optimization process.
View the Results
The Post Processing task should be selected in the Process Manager. When the fatigue
optimization is finished successfully, it will automatically go into this task.
In the panel area, click Load H3D Results(HV).
Figure 13.
HyperView opens and loads the
tarm_fatigue_opti_s4.h3d results file
for life results on top of shape results.
In the Results Browser, select the last iteration
(Iteration 11).
On the Animation toolbar, click to stop the animation.
Set the animation mode to (Transient).
The Life Contour on top of shape results displays.
On the Results toolbar, click to open the
Contour panel.
In the Legend tab, click Edit Legend to edit the legend so that it is the same
as Figure 14 and Figure 15.
Click Exit to unload fatigue process manager.
Figure 14. Life contour of Iteration 0. volume = 4.674E+02, minimum Life = 2.053E+04. Figure 15. Life contour of iteration 11. volume = 3.78213E+02, minimum Life = 2.053E+04.
