2024
Discover OptiStruct functionality with interactive tutorials.
Tutorials using Classic HyperMesh.
View new features for OptiStruct 2024.
OptiStruct is a proven, modern structural solver with comprehensive, accurate and scalable solutions for linear and nonlinear analyses across statics and dynamics, vibrations, acoustics, fatigue, heat transfer, and multiphysics disciplines.
In this tutorial you will perform a combined topology and topography optimization on a slider suspension using OptiStruct.
Composite materials have become popular in the application of aircraft structures. The need for innovative designs has posed a great challenge. In this tutorial you will perform an optimization-driven design approach of a composite aircraft underbelly fairing using OptiStruct.
In this tutorial you will learn how to set up a basic lattice concept-level (Phase 1) optimization using the DTPL card, set up and review the basic options associated with lattice optimization, and set up a basic lattice fine-tuning (Phase 2) optimization and review the results.
Composite materials have become popular in the application of a variety of structures. The need for innovative designs has posed a great challenge. In this tutorial you will perform an optimization-driven design approach of an open-hole tension specimen using OptiStruct.
This section presents nonlinear explicit analysis examples generated using OptiStruct. Each example uses a problem description, execution procedures, and results to demonstrate how OptiStruct is used.
Tutorials using HyperMesh.
Video tutorials using SimLab.
This manual provides detailed information regarding the features, functionality, and simulation methods available in OptiStruct.
This manual provides a detailed list and usage information regarding input entries, output entries, and parameters available in OptiStruct.
The OptiStruct Example Guide is a collection of solved examples for various solution sequences and optimization types and provides you with examples of the real-world applications and capabilities of OptiStruct.
This manual presents solved verification models including NAFEMS problems.
This section provides quick responses to typical and frequently asked questions regarding OptiStruct.
