Run OptiStruct from HyperMesh
Before you begin, copy the file(s) used in this tutorial to your
working directory.
This tutorial demonstrates how to launch an OptiStruct job from within HyperMesh. A HyperMesh database containing a fully defined OptiStruct finite element model is retrieved and an OptiStruct job is launched from the OptiStruct panel in HyperMesh.
Launch HyperMesh and Set the OptiStruct User Profile
Launch HyperMesh.
The User Profile dialog opens.
Select OptiStruct and click
OK.
This loads the user profile. It includes the appropriate template, macro menu, and import reader, paring down the functionality of HyperMesh to what is relevant for generating models for OptiStruct.
Open the Model
- Click .
- Select the plate.hm file you saved to your working directory.
Click Open.
The plate.hm database is loaded into the current HyperMesh session, replacing any existing data.
Submit the Job
From the Analysis page, click the OptiStruct
panel.
Figure 1. Accessing the OptiStruct Panel
- Click save as.
In the Save As dialog, specify location to write the
OptiStruct model file and enter
plate for filename.
For OptiStruct input decks, .fem is the recommended extension.
Click Save.
The input file field displays the filename and location specified in the Save As dialog.
- Set the export options toggle to all.
- Set the run options toggle to analysis.
- Set the memory options toggle to memory default.
- Click OptiStruct to launch the OptiStruct job.
The default files written to the directory are:
- plate.html
- HTML report of the analysis, providing a summary of the problem formulation and the analysis results.
- plate.out
- OptiStruct output file containing specific information on the file setup, the setup of your optimization problem, estimates for the amount of RAM and disk space required for the run, information for each of the optimization iterations, and compute time information. Review this file for warnings and errors.
- plate.h3d
- HyperView binary results file.
- plate.res
- HyperMesh binary results file.
- plate.stat
- Summary, providing CPU information for each step during analysis process.
Post-process the Results
While still in HyperMesh, launch HyperView after the job has finished from the OptiStruct panel.
Click HyperView.
HyperView opens and automatically loads the H3D
file from the OptiStruct job for
post-processing.
