OS-T: 5000 2D Shape Optimization of a Cantilever Beam
In this tutorial you will perform a shape optimization on a cantilever beam modeled with shell elements.
![5001-1](../../../images/solvers/5001-1.png)
The structural model is loaded into HyperMesh and is used to generate and run a shape optimization of the cantilever beam. Shape perturbation vectors are generated using HyperMorph, which is accessed, through the HyperMesh interface. The OptiStruct software determines the optimal shape. The results are then reviewed in HyperView.
- Objective
- Minimize volume.
- Constraints
- Given maximum nodal displacement at the end of the beam < 3.0 mm.
- Design Variables
- Shape variables defined with HyperMorph.
Launch HyperMesh and Set the OptiStruct User Profile
Launch HyperMesh.
The User Profile dialog opens.
Select OptiStruct and click
OK.
This loads the user profile. It includes the appropriate template, macro menu, and import reader, paring down the functionality of HyperMesh to what is relevant for generating models for OptiStruct.
Open the Model
- Click .
- Select the beamshape.hm file you saved to your working directory.
Click Open.
The beamshape.hm database is loaded into the current HyperMesh session, replacing any existing data.
Set Up the Optimization
Create Shapes using HyperMorph
- From the Analysis page, click the optimization panel.
- Click the HyperMorph panel.
Create domain handles.
- Click the domains panel.
- Select the create subpanel.
- Switch from global domains to auto functions and keep the default settings.
- Click generate.
- Click return to return to the HyperMorph panel.
A number of domains and handles are created which will enable us to morph the shape of the beam.
There are two types of handles: global handles, which are represented by larger red balls; and local handles, which are represented by smaller yellow balls. Only local handles will be covered in this tutorial.
Move handles.
The beam changes shape, so that the handle you selected moved to the location of the node you selected. Notice how the mesh adjusted to this change in shape.
Figure 3. Morphed Shape 1
Save the shape.
- Select the save shape subpanel.
- In the shape= field, enter shape1.
- Click the color button to select a new color for the shape vectors.
- Under shape=, set the toggle to as node perturbations.
- Click save.
- Click Yes.
This shape has been saved and can be associated with a design variable later. -
Click undo all.
The model returns to the original shape.
Create handles.
A new handle, 'aux1', is created at the center of the top edge of the beam.
Figure 4.
Move the handles.
Figure 5. Morphed Shape 2
Set biasing.
The curvature of the top edge has altered.
Figure 6. Morphed Shape 3
Save the shape.
- In the shape= field, enter shape2.
- Click save.
- Click Yes if you wan to save perturbations for nodes at global and morph volume handles.
This shape is now saved, later it can be associate to a design variable. -
Click undo all.
The model returns to its original shape.
- Click return twice to return to the Optimization panel.
Create Shape Design Variables
- Click the shape panel.
- Select the desvar subpanel.
- Switch the design variable option from single desvar to multiple desvars.
- Using the shapes selector, select shape1 and shape2.
- Click create.
- Click return to return to the Optimization panel.
Create Optimization Responses
- From the Analysis page, click optimization.
- Click Responses.
Create the volume response, which defines the volume fraction of the design
space.
- In the responses= field, enter vol.
- Below response type, select volume.
- Set regional selection to total and no regionid.
- Click create.
Create the displacement response.
- Click return to go back to the Optimization panel.
Create Design Constraints
- Click the dconstraints panel.
- In the constraint= field, enter constr.
- Click response = and select disp.
- Check the box next to upper bound, then enter 3.0.
- Using the loadsteps selector, select Load.
- Click create.
Define the Objective Function
- Click the objective panel.
- Verify that min is selected.
- Click response and select vol.
- Click create.
- Click return twice to exit the Optimization panel.
Define the SHAPE Card
- From the Analysis page, click the control cards panel.
- In the Card Image dialog, click SHAPE.
- Set FORMAT to H3D.
- Set TYPE to ALL.
- Set OPTION to ALL.
- Click return twice to go back to the main menu.
Run the Optimization
- From the Analysis page, click OptiStruct.
- Click save as.
In the Save As dialog, specify location to write the
OptiStruct model file and enter
beamshape for filename.
For OptiStruct input decks, .fem is the recommended extension.
Click Save.
The input file field displays the filename and location specified in the Save As dialog.
- Set the export options toggle to all.
- Set the run options toggle to optimization.
- Set the memory options toggle to memory default.
Click OptiStruct to run the optimization.
The following message appears in the window at the completion of the job:
OPTIMIZATION HAS CONVERGED. FEASIBLE DESIGN (ALL CONSTRAINTS SATISFIED).
OptiStruct also reports error messages if any exist. The file beamshape.out can be opened in a text editor to find details regarding any errors. This file is written to the same directory as the .fem file. - Click Close.
View the Results
View the Shape Results
From the OptiStruct panel, click HyperView.
HyperView launches within the HyperMesh Desktop and loads beamshape_des.h3d on page 1 and beamshape_s2.h3d opens on page 2.
Use the navigations buttons to navigate to Design History on page 1.
Figure 7.
In the Results Browser, select the iteration.
Figure 8.
On the Results toolbar, click
to open the Contour panel.
- Set the Result type: to Shape change (v) and Mag.
- Click Apply.
![5000_shape_opt_results](../../../images/solvers/5000_shape_opt_results.png)
View a Contour Plot of the Displacement
- In the top, right of the application use the navigation buttons to move to page 2.
In the Results Browser, select the last iteration.
Figure 10.
- On the Results toolbar, open the Deformed panel.
- Set the Result type: to Shape Change (v).
Click Apply.
The optimized shape of the beam displays.
- Set the Result type: to Displacement (v) and Mag.
- Click Apply.
On the Annotations toolbar, click
to open the Measures panel.
- Select Static MinMax Result.
![5000_final](../../../images/solvers/5000_final.png)
