Create Beads
Beads are typically used to stiffen panel mesh to meet a certain performance criteria. The Bead tool can also be used as a topography interpretation mechanism.
                From the Concept ribbon, click the Bead tool.
 - Optional: Select 2D elements on which the beam is to be created.
                Create beads in one of two ways:
- Select existing lines.
 - Interactively draw a bead line path. Select two points to create the initial bead, then incrementally add points.
A preview is displayed showing the location, orientation, and basic dimensional composition of the bead(s). -
                Update any of the bead's properties using the microdialog.
- Reverse the side the bead is created on.
- Move the bead in 3D space. Once relocated, the bead snaps to the underlying 2D mesh.
 - Height/Width
 - Dimensions of the bead.
 - Cap end
 - Change the cap end from rounded to squared.
 - Cap length/Cap end width
 - Dimensions of the bead cap.
 - Click Add Bead.
 - If desired, repeat the process multiple times to continue adding beads.
 - Click Create Beads on the guide bar.
