Modify a Curve from the View Dependencies Dialog
                In HyperGraph, right-click on a curve and select
                        Dependencies from the context menu.
                The View Dependencies dialog is displayed.
 - The curves that you selected and all curves that define it are listed in the left panel of the dialog.
 - The right panel of the dialog contains source information about each curve.
 - From the left panel, select the curve you want to modify.
 - From the right panel, select the modifications that you want to make to the curve.
                Click Apply.
                The selected curve is modified.Note: If a curve name listed in the left panel is too long, select Line wrap to wrap the name of the curve so that it fits in the panel.
