2025
Add horizontal and vertical datum lines to plots.
View new features for Altair HyperWorks 2025.
The Developer ribbon contains tools for automation and customization.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
Edit existing curves and add new curves to the current plot.
Retrieve individual point data on any curve in the active window. When a point is selected, the point data is displayed in the dialog.
See Datums for more information.
