2026
Plot data can be post-processed using both HyperMesh and HyperGraph.
Add horizontal and vertical datum lines to plots.
View new features for Altair HyperWorks 2026.
Create, organize, and manage parts and subsystems.
The Developer ribbon contains tools for automation and customization.
Use the Chart Manager to plot your analysis results.
Learn how to manipulate plot data using the Plot Browser and other user interface tools and options.
Edit existing curves and add new curves to the current plot.
Retrieve individual point data on any curve in the active window. When a point is selected, the point data is displayed in the dialog.
Displayed immediately upon curve selection, this tool calculates and draws the tip to tail function based on the current plot.
See Datums for more information.
