Convert Units
Convert the current unit of measure for a horizontal or vertical axis to another unit of measure.
To access this option, right-click on any plot axis and select Edit from the context sensitive menu.
Note: To select this option from a curve's context menu,
right-click on a curve and select .
When you select the context menu option, the application automatically selects the current axis unit of measure. For instance, if the horizontal axis unit of measure is time, time will be selected when the Entity Editoris displayed. If the application cannot detect the current axis unit of measure, it automatically defaults to time.
You can select units of measure from the following categories:
- Time
- Distance
- Velocity
- Acceleration
- Moment
- Force
- Pressure
- Angle
- Angular velocity
Select the new axis unit of measure to convert the current axis unit of measure accordingly.
