A scrolling selection bar helps to choose the section in which one can define the
winding settings.
Here are the sections available to design the winding step by step:
“Scheme” to build the winding architecture.
“Coil” to set how the coil is defined and to see how the slots are
filled.
“Insulation” to define all the winding insulations.
“End winding” to define the topology and dimensions of the
end-windings.
“X-Factor” to adjust phase resistance and end-winding inductance.
“Potting” to define the topology and dimensions of the potting around the
end-winding.
Note: The “Potting” section is available only when the
housing is defined with a frame (circular or square shape).
Figure 1. Sections to design the winding step by step
Note: In the software winding datasheet, the parameters
written in blue correspond to user input parameters and the parameters written
in black correspond to data resulting from computations.
Terminology
Refer to the section “Terminology – Illustration” dedicated to classical and hairpin
winding technology.
Classical winding outputs
Please refer to the section “Winding / Winding outputs” dedicated to classical and
hairpin winding technology.
