Potting
“Potting” section is available only when the housing is defined with a frame (circular or square shape).
Table 1. Definition of the topology and dimensions of the potting around the end-winding
1 Button to define a potting with only radial contact (at connection side in this example)
2 Button to define a potting with radial and axial contacts (at opposite connection side in this example).
3 Dimensions for defining the selected potting
4 Extension of potting with both contact axial and radial
5 Extension of potting with radial contact only
