Winding
Overview
In Motor Factory, depending on the considered machine type, there are several types
of winding technology:
- 3-Phase classical winding
- Polyphase classical winding
- Hairpin winding
- Field winding
- DC winding
The table below indicates which machines these different types of windings are compatible with.
| 3-Phase classical |
n-Phase classical |
Hairpin | Field | DC | |
| SM_PM_IR Synchronous Machine with Permanent Magnets - Inner Rotor |
| SM_PM_OR Synchronous Machine with Permanent Magnets - Outer Rotor |
| SM_RSM_IR Reluctance Synchronous Machine - Inner Rotor |
| SM_WF_ISP_IR Wound Field Synchronous Machine Inner Salient Pole – Inner Rotor |
| IM_SQ_IR Induction Machine with SQuirrel cage - Inner Rotor |
| IM_SQ_OR Induction Machine with SQuirrel cage - Outer Rotor |
| DC_PM_IR Permanent Magnet DC machine |
