Correction tools: global correction
Global correction
The global correction tools permit to accurately render automatically according to the whole geometry on which there are potential faults. Several tools are available :
- Heal all intersections
- Heal all superimpositions
- Simplify all lines
- Heal and simplify all geometry
Access
The different accesses for this mode of creation are presented in the following table:
| Access | |
| Heal all intersections | icon: |
| menu: | |
| Heal all superimpositions | icon: |
| menu: | |
| Simplify all lines | icon: |
| menu: | |
| Heal and simplify all geometry | icon: |
| menu: | |
The correction tool « Heal all intersections » permits to correct automatically all the intersections detected on the assembly of the geometry. On each intersection a fragmenting is made.
Heal all superim-positions
The correction tool « Heal all superimpositions » permits to correct automatically all the superimpositions of the lines detected on the assembly of the geometry. On each superposition, a merge is made so as to create a single line on the common sections.
Simplify all lines
The correction tool « Simplify all lines » permits to simplify automatically all the configurations of two adjacent lines, collinear and not superimposed on the assembly of the geometry in a single line.
The correction tool « Heal and simplify all geometry » permits to carry out together global corrections in one action, namely: correct all the intersections, all the superimpositions and simplify all the lines of the geometry.
