Lines and faces: authorized shapes
Lines and faces
Lines and faces can be:
- created by Flux
- or imported within a CAD file.
Their shapes depend on their origin.
Lines created by Flux
The shape of line depends on the tool used by Flux to build the geometry. The lines created by Flux are as follows:
| Shape of line | Construction |
Lines imported in Flux
Within the CAD file importation into Flux project, the lines of an unspecified shape can be imported.
Faces built by Flux
The shape of face depends on the tool used by Flux to build the geometry. The faces built by Flux are as follows:
| Shape of face | Construction |
Faces imported in Flux
Within the CAD file importation into Flux project, the faces of an unspecified shape can be imported.
