Generalized projective method
Introduction
This chapter discusses the use of the Generalized projective method to create force collections in the Import / Export data context : this kind of collection allows to compute forces on a generic mesh (i.e., a set of points) with the aim to be exported towards OptiStruct to setup a NVH analysis of electrical devices, such as rotating machines. This method and then the collection created may be seen as an extension of the simplified projective method dedicated to rotating machines which overcome its limitations.
The following topics are covered in this page:
- Description of the approach
- Creation of this force collection
- Example
- In the case of the Maxwell tensor method, the set of supports to compute and integrate the magnetic pressure must be located in air regions and can be defined by an extruded path, a 2D grid as shown in (a) part of Figure 1 or an extruded geometric line. All the components of the magnetic pressure are locally integrated on the computation supports before being projected on the support chosen to collect the data.
- In the case of the nodal virtual work method, the set of supports to compute forces must be located on the geometric entities at borders of regions (lines or extruded lines in 2D, faces in 3D). The forces will be directly computed on the nodes of the supports before being projected on the support chosen to collect the data.
Creation of this collection
- In the data tree, select the menu Forces data collection
- In the dedicated GUI for Forces data collection, select Generalized projective method
- In the Definition tab:
- Choose an imported data support to collect the data
- Choose the computation method
- Choose a list of data supports to compute forces
- In the Advanced tab, the user can decompose the computed forces in
radial and tangential components. To this aim, he is invited to:
- Select the rotation axis (X, Y or Z expressed in XYZ1 coordinate system)
- Choose a pivot point by its coordinates and a coordinate system
- Choose the collection interval:
- Collect for all the steps of the scenario
- Collect only for the current step
- Collect for a specified interval
- Click OK
- Right click on the forces data collection just created in the data tree and run the command Collect data
In this example, the aim is to compute the global force on each tooth of the 3D axial flux machine described in Figure 1 after solving a scenario in Flux.
To this aim, a support to collect the data is imported from OptiStruct which is the same as part (b) of Figure 1. The Maxwell computation method is chosen then the computation support is defined in the airgap region by a 2D-grid (see (a) of Figure 1).
