Thermal data collection
The thermal data collections are divided in two types, corresponding to specific data types:
- The Joule losses (obtained with the computation of the spatial quantity dLossV). These losses can only be computed on volume supports situated on conductors. The user should specify:
- The type of data to be collected (nodal values, integrals at nodes, average in elements, integrals at elements).
- The temperatures (obtained with the computation of the spatial quantity TKelvin). All supports are compatible. The user should specify:
- the temperature unit (Kelvin, Celsius or Fahrenheit)
- the localization of the values (at the nodes or in the elements)
