Derived data collection
The derived data collections enable to define data collections by applying an operation on one (or several) existing collections. These derived collections are divided in three types:
  • Fourier transformations, obtained applying an FFT algorithm to the values of a collection. Only the collections defined on a time interval are compatible. The created collection inherits of the transformed collection support. The user:
    • should specify the specific step interval,
    • can tick or not the option Preserve mechanical harmonic rank for rotating machines. If activated, this option computes the FFT for a period based on a full rotor turn, inserting zero harmonics for non representative frequencies and so preserving all mechanical harmonic ranks based on the mechanical fundamental frequency. The rotating speed of the mechanical set must be constant.
    Note: To prevent corruption of results by high frequency numerical noise, the computed harmonics are limited to those with frequencies lower than the numerical cutoff frequency set to 1/(4Δt).
  • Simple operators, enabling to extract the different values, Maximum, Minimum,Average (statistics), Sum or RMS Values of a multi-steps collection. Single step collections are not compatible. The created collection inherits of the transformed collection support. The user should specify:
    • a specific step interval,
    • the operator to apply.
  • Harmonic excitations, which allows to define a collection similar to the collections obtained by Fourier transform, but by defining directly different components values (continuous and harmonic) through the combination of other collections values. The chosen collections to compose this type of collection must share the same support and a same data type (nodal or elementary, scalar or vectorial). The created collection inherits of the transformed collections support. The user should specify:
    • a collection defining the continuous component. This collection values should be reals,
    • a collection defining the harmonic component. This collection values should be complexes,
    • a frequency associated to the harmonic.
