B(H) curve of a material: environment
2D curve (Material): Environment
The environment of a 2D curve (Material) is similar to the environment used for the 2D curves (path) and the 2D curves (I/O parameter).
The functionalities of this environment are similar to functionalities of the 2D curve environment.
