Adding a Voltage Source
Add a voltage source to the port of the monopole.
On the Source/Load tab, in the
Sources on Ports group, click the
Voltage Source icon.
The radiated power must be 1 Watt for this example. Since the input
impedance for the monopole is not known, the voltage can not be changed to scale the
radiated power.
Ensure WirePort1 is selected in the drop-down list and use the default voltage settings.
Click Create to define the voltage source and to
close the dialog.
Figure 1. Front view of the monopole and transmission line together with their wire ports. The wire port with a voltage source applied to it, is indicated by a red sphere.
