Setting the Simulation Frequency
Specify the frequency range of interest. For this example continuous frequency sampling is used where Feko determines the frequency sampling for optimal interpolation automatically.
On the Source/Load tab, in the
Settings group, click the
Frequency icon.
- On the Solution Frequency dialog, select Continuous (interpolated) range from the drop-down list.
Specify the frequency range between 1 MHz and
30 MHz.
Enter the start frequency and end frequency.
- Start frequency (Hz): 1e6
- End frequency (Hz): 30e6
Figure 1. The Solution Frequency dialog.
- Click OK to specify the frequency and to close the dialog.
