Setting the Simulation Frequency
Specify the frequency range of interest. For this example continuous frequency sampling is used where Feko automatically determines the frequency sampling for optimal interpolation.
The example is intended for users with no or little experience with CADFEKO. It makes use of a completed rectangular horn model to familiarise yourself with model creation in CADFEKO and viewing the simulated results in POSTFEKO.
The example is intended for users with no or little experience with CADFEKO. This example is not an example intended for simulation, but rather to familiarise yourself with model creation in CADFEKO.
The example considers a left-handed circular polarised GPS patch antenna on a finite substrate.
The example considers the antenna placement of a GPS patch antenna on a quadcopter.
Calculate the input reflection coefficient and circular components of a left-handed circular polarised GPS patch antenna on a finite substrate close to 1.57 GHz placed on a quadcopter. Compare the results with that of Example 3.
Before starting this example, ensure that the system satisfies the minimum requirements.
Create the model geometry using the CAD component, CADFEKO.
There are several options available to launch CADFEKO in Windows.
There are several options available to launch CADFEKO in Linux.
Set the model unit to millimeters.
Select a simplified quadcopter model from the Component library and add it to the project.
Import the GPS patch antenna (.cfx file) created in Example 3.
Entities in the model tree and details tree can be hidden by clicking on the entity’s icon.
Make the simulation mesh hidden in the 3D view focus on the geometry.
To assist in placing the patch antenna, two workplanes are defined and used in the Align tool.
Save the model to a CADFEKO.cfx file.
Launch the Solver to calculate the results. No requests were added to this model since impedance and current information are calculated automatically for all voltage and current sources in the model.
Display the model as well as the results using the post-processor component, POSTFEKO.
This examples showed how to place a GPS patch antenna on a quadcopter that was obtained from the component library.
The example considers the coupling between a typical monopole antenna and a loaded transmission line above a ground plane.
The example considers the transmission and reflection coefficients of a waveguide power divider.
The example considers the optimisation of the gain of a bent dipole in front of a plate.
