Topics Discussed in Example
The topics discussed in this example are:
- CADFEKO
- Specify the model unit.
- Add a component from the component library.
- Import a model from a .cfx file.
- Create a workplane and perform transformations on the workplane (rotate).
- Use the Align tool for antenna placement.
- Run the .
- Show/hide the simulation mesh in the 3D view.
- Show/hide a part in the 3D view.
- POSTFEKO
- View the Lua script to set up the graphs
(similar to Example 2) for the following:
- View the input reflection coefficient on a Cartesian graph.
- View the left-hand and right-hand circular components of the far field on a Cartesian graph.
- View an example of a Lua script to configure graphs.
Note: Follow the example steps in the order it is presented
as each step uses its predecessor as a starting point.
1 The
application macro library is located on the Home tab, in the
Scripting group. Click the Application
Macro icon and from the drop-down list, select
Getting Started Guide.
