Microstrip Patch Antenna
Model a microstrip patch antenna using two feed methods (pin feed, microstrip edge feed). The dielectric substrate is considered as a finite substrate and an infinite planar multilayer substrate.
The far field results are compared for the following configurations:
- Pin-fed, finite ground and solved using MoM (SEP).
- Pin-fed, finite ground and solved using the FDTD.
- Pin-fed, infinite substrate and solved using the MoM with the planar Green's function for multilayered media.
- Edge-fed, infinite substrate and solved using the MoM with the planar Green's function for multilayered media.
The simulation time and resource requirements are greatly reduced when using an infinite plane, although the model is a less accurate representation of the physical antenna.
Tip: Each model uses its predecessor as a starting
point. Create the models in their presentation order. Save each model to a new
location to keep them.
