Monopole Antenna on a Finite Ground Plane
Calculate the radiation pattern for a wire monopole antenna on a finite ground plane. The ground plane is modelled as a circular PEC ground plane.
Tip: Find the completed model in the application macro library1.
1 The
application macro library is located on the Home tab, in
the Scripting group. Click the Application
Macro icon and from the drop-down list,
select Example Guide.
