What's New
This section provides an overview of the main new features in EDEM version 2026 and highlights key updates.
Settings
You can now set a default gravity value in dialog box, making it easier to use custom gravity directions or values.
Analyst
New attributes are available in Analyst, including Particle Aspect Ratio, Acceleration, Scale, and Mass Scale. You can also export selected Geometries to STL files.
API
API versions before 3.0 are deprecated. Coordination numbers and Geometry details are now accessible in more Plugin functions. The Factory API is updated for consistency and easier use.
Coupling
EDEM-OptiStruct Coupling now allows you to specify the port number for connections.
EDEMpy
EDEMpy 1.9.0 adds a particle acceleration attribute, improves property list handling, and updates Python to version 3.10.
Contact Models
The Wet Mixing model is deprecated. The Heat Conduction model now supports per-element heat tracking and is compatible with EDEM-OptiStruct Coupling.
