On-Demand Libraries
Optionally install on-demand libraries through the Extension Manager.
Note that when using the Extension Manager as a library loader, commands in use through the loader.oml and unload.oml files may affect the behavior of the Extension Manager.
Altair CAE Readers and Writers
This extension contains Altair CAE Reader and Writer libraries.
Modules
- ABF - Commands used to create and write data in Altair Binary format (*.ABF).
- CAE Readers - Commands use Altair Readers to read data from a given CAE results file.
- CAE Readers 3D - Commands use Altair Readers to read data that require access to model information like corner data, averaging method, layer, and coordinate systems.
- CAE Writers - Commands used to create, write (new and append) data in Altair H3D format.
- CAE Reader Utility - GUI Utility to manually select and get commands for extracting data from a CAE/Test result file.
Altair Production Integration
This extension contains Hyperstudy Python Fit and Multibody Postprocessing workflow.
Modules
- Multibody Processing - This library supports multibody-related and multi-disciplinary workflows and system-level vibration analysis in time and frequency domains.
- Hstpyfit - Commands read and evaluate Hyperstudy .pyfit.
Altair Advance Optimization
This extension contains advance optimization algorithms.
- arsm - Find the constrained minimum of a real function.
- arsmoptimset - Specify the arsm optimization function options.
- grsm - Find the constrained minima of a real multi-objective function.
- grsmoptimset - Specify the grsm optimization function options.
- moga - Find constrained minima of a real multi-objective function.
- mogaoptimset - Specify moga optimization function options.
OMLPY
OMLPY is an extension that lets you seamlessly call OML built-in functions and user-defined functions from within a Python environment of Altair products like Compose, HyperMesh, HyperGraph, HyperView, and Inspire.
Introduction
An overview of the OMLPY extension.
- All OML built-in functions are accessible.
- Ability to run user-defined functions in .oml file from Python and get the output back to Python.
- Python data types are automatically mapped to OML data types.
- Demos available in the Demo Browser after loading the extension.
Use
Basic use of OMLPY.
To use OMLPY, from Python, instantiate the OmlPy class and start using OML functions.
OMLPY leverages a two-way bridge that enables communication between Python and OML in Compose to share data in memory.
from omlpy import OmlPy
x=OmlPy()
t = x.linspace(0,1000,1000) #evaluates oml built-in command - linspace
All OML errors are caught and displayed in Python automatically. An attribute error is thrown if any function is not available in the given product environment.
Functions
In addition to support of OML built-in commands, OMLPY comes with the ‘omlfunction’ method, which lets you run an OML function defined in an OML file.
omlfunction
Evaluates an OML function from a specified file name and arguments.
omlfunction(self,filename,func, *args, **kwargs):
- filename : filename
- The file location of the OML file.
- func : str
- OML function name to evaluate.
- *args :
- Arguments to the OML function.
Outputs
- A list of outputs from the OML function.
import numpy as np
wp=500; # Passband frequency
ws=2000; # Stopband frequency
Rp=3; # Passband ripple
Rs=20; # Stopband attenuation
Fs=8000; # Sampling frequency
Fn=Fs/2; # Normalized sampling frequency
x = OmlPy()
f = x.linspace(0,4000,10) # running linspace oml built-in command
#calling user defined function from filename
filename = './ButterworthFilterDesign.oml'
x.omlfunction(filename,'ButterworthFilterDesign',f,wp,ws,Rp,Rs,Fs,Fn)
Install a Library in the Extension Manager
Select .
The available libraries are listed with their corresponding extensions.
On the library you want to install, slide the install button to the right
The library automatically becomes available in the Library Browser. For example, if you install the Multibody Processing library, you will see it displayed with the core libraries.
Uninstall a Library in the Extension Manager
Select .
On the library you want to uninstall, slide the install button to the left
Note that a native Compose library, such as MultibodyProcessing, is uninstalled, but not removed from your system. Even if you click the Remove button, the library is removed for your current session only and remains on your system should you wish to re-install it later in a new session.
Using the librarymanager Function
When using the librarymanager function to install or uninstall a native, on-demand library, the library status (installed or uninstalled) that you define wih the function is automatically reflected in the Extension Manager.
