CAE Reader
Use the CAE Reader to import and work with CAE test data.
The CAE Reader leverages Altair HyperGraph™ to import and read in CAE data without the need of a translator or converter.
Supported Files and Formats
- Time and frequency-based data formats.
- Files generated with Finite Element method, Computational Fluid Dynamics, and Multibody System solvers.
- File formats: .unv, .iso, .ascii, .csv, and others.
CAE Reader Options
| Option | Description |
| File | Navigate to the CAE file that you want to load. |
| Subcase | Select a subcase for the specified CAE file. |
| Type | Select a result type based on the specified subcase. |
| Search box | Type a string to search in the requests, components, and timesteps. You can use regular expressions with wildcards like * or Match Case. |
| Requests | Choose an option to enter requests:
| Components | Select one or more components based on the specified subcase and
result type. Before making your selection, you can use the Filter option to display only filtered components. These are components without data that are hidden by default. Select All to select all visible components. If Filter is specified, only the filtered components are selected. |
| Output | Output is matrix or cell: Matrix format
with numeric data: Cell
format: ![]() ![]() Where:
| Plot Style | Choose Line or
Scatter. Note: If
you select one request, one component, and many timesteps, the
scatter plot style is used by default to differentiate the time
step data. |
| Select the Print button to enable the
importing of the data. The command generated can be used within any
script. The size of the expected output of the Print command is displayed in the message bar: Output of Print command will have size 4x3x1 which represents the size of a matrix output as [Requests x Components x Time Steps]. |
| Preview | Select the Preview button and review the
defined line or scatter plot, which is 2D or 3D depending on the
number of specified requests, components and time steps.
| Import | Select the Import button, then import data
into the workspace with the name data. Note: If a data variable
already exists in the workspace, the software prompts you to
confirm if the variable should be overwritten or
not. |
| Stop | Select the Stop button to end the file
importing. Note: This option is not valid for
ODB files. |
