Library Creator
Use the Library Creator tool to create, modify, and encrypt extensions to be used in the Extension Manager.
The Library Creator is located in the File Utilities ribbon.
The Library Creator opens in a dialog box with two tabs, Basic Info and Optional. These tabs let you create a plugin.xml, loader.oml, unload.oml, and organized folders to be used as an extension.
- Create an extension from scratch by entering basic info and optional files.
- Create an extension from scratch by entering basic info, optional files, and encrypting the extension.
- Load an existing extension to modify and encrypt it.
- Load an existing extension to encrypt it.
Basic Info Tab
| Option | Description |
| Name | Enter the name of the extension. |
| Description | Enter a short description of the extension. |
| OML File Paths |
Select the folder from which OML files and functions will load, unload, and populate with the auto-completion feature in Compose. After you click Create, all contents are copied from the selected folder to <extension>/scripts/oml. |
| Version | Enter the version of the extension. |
| Encrypt Library | Select the check box to encrypt the extension. All OML files are encrypted in subfolders except for the demos folder. |
| Create | Creates an extension with
plugin.xml,
organized folders as in the image below.
The scripts folder has an OML subfolder will all the selected OML file paths. |
| Load | Automatically populated fields in both tabs from the selected extension. The tool reads plugin.xml from the selected extension. |
| Reset | Resets to default settings, emptying the fields in both tabs. |
Optional Tab
| Hidden File Paths | Select the OML files and functions that the extension will
register as hidden paths. This is similar to OML File Paths in the Basic Info tab, but functions in these OML scripts do not populate in the autocompletion feature of Compose. |
| Author | Enter author information. |
| Resources | Any resources that you want in the extension. Currently, /icons is supported. |
| Minimum Version | Minimum product version that this extension will work with. |
| Documentation | Point to the help documentation or help folder. Supported file types are .DOCX, .PDF, .HTML, and web links. |
| Demos | Select the demos folder to be shown in the demo browser when the extension is loaded. |
| Third-party | Select the third-party folder for the extension. This creates an empty third-party folder for future additions. |
| Source Code | Select source code folder for the extension. This creates an empty src folder for future additions. |
| Icon | Select the image to be shown for the extension. |
