Define the Models
As you are going to have multiple Things defined with the same schema, the first step will be to define a Model inside AnythingDB for each of the devices. Models are templates to store a default Thing schema to ease the process of adding new Things quickly.
The three following Models need to be created:
- Traffic Light
- Traffic Sound Sensor
- Parking Sensor
- Under New Model. , choose to add a
- Complete the information for the Properties, Actions and Events as defined below (or disable them if the Thing doesn’t have any).
Name the first Model TrafficLight and click
Create
Name the second Model TrafficSoundSensor and click
Create.
Name the third Model ParkingSensor and click
Create.
- In the panel on the right that appears, enter Thing Title as Parking Sensor.
- Click the plus sign next to Properties and create a Property named Presence with type Boolean.
- Click Save.
Note: Multiple versions of a Model can be implemented, to enable you to easily update schemas while defining your project. You can include a version title and version description to keep track of the changes.
