Model the Smart City Ecosystem
Things represent the entities in the smart connected ecosystem and store information about them. They are the virtual digital representations of the asset (IoT sensor, machine, device...).
Based on the Web of Things (WoT), Things can be defined through JSON formatting based
on properties, actions, and events.
- Properties
- Describe the Thing's attributes (e.g., sensor values, configuration parameters, status, results of an analysis)
- Actions
- Determine how you can interact with your Thing (e.g., change a property, turn on/off)
- Events
- Monitor the changes that can modify a Thing’s property (e.g., fire alarm, door open, data streams)
Following the Smart City example, our Things will be the different sensors and traffic assets, and they will have the following attributes:
| Thing | Property | Action | Event |
| Traffic Light | State, Geo Location | Turn On/Off | Burn out |
| Traffic Sound Sensor | State, Geo Location | Turn On/Off | N/A |
| Parking Sensors | Presence | N/A | N/A |
| Air Quality Sensor | Air quality index, temperature, humidity | N/A | High Value |
