Developer Installation
This section is intended for developers creating their own third party service (device driver or support service).
K3d
Requirements:
  • docker to be able to use k3d at all
  • kubectl to interact with the Kubernetes cluster
Note: k3d v5.x.x requires at least Docker v20.10.5 (runc >= v1.0.0-rc93) to work properly.
Installation of the latest version of K3d can be done using curl:
curl -s https://raw.githubusercontent.com/rancher/k3d/main/install.sh | bash
A new Cluster can now be created as follows:
k3d cluster create mycluster
A list of Clusters can be shown as follows:
k3d cluster list
For complete K3d documentation see the website or run
k3d --help
Once the Cluster is up and running you can use kubectl from the command line to interact with it.
