Standard inputs
  1. Field current
    The current supplied to the field winding of the machine: “Field current” must be provided.
  2. Speed
    The operated speed of the machine to be used in the back-EMF test.
Advanced inputs
The list of advanced inputs dedicated to this export are listed below.
For more details, please refer to the section 4.7.5 - List of generic advanced inputs.
  1. Number of computations per electrical period
    The default value is equal to 50. The minimum allowed value is 13.
  2. Number of computed electrical periods
    The default value is equal to 2. The minimum allowed value is 1 and the maximum value is equal to 10.
  3. Rotor initial position
    By default, the “Rotor initial position” is set to “Auto”.
  4. Mesh order
    The default level is second order mesh.
  5. Airgap mesh coefficient
