No-Load short circuit
Characterization – Short circuit – Motor & Generator – Three / Two / Single Phase
Positioning and objective
The aim of the export “Characterization - Short circuit – Motor & Generator – Three / Two / Single Phase” is to characterize the behavior of the machine, when running in short circuit state happening between three phases, two phases or a single phase.
The resulting model is fully parameterized, and it is built in Flux® 2D environment, transient application.
The following section describes all the user inputs to initialize the exported model.
All these parameters can be modified in Flux® 2D environment, if needed.
