Standard inputs
- Type of short circuitThe type of short circuit can be chosen among a list of choice:
- Three phase: the three phases of the stator windings are short circuited.
 - Two phase: the first phase and second phase of the stator windings are short circuited.
 - Single phase: the first phase of the stator windings is short circuited.
 - Field voltage
The voltage supplied to the field winding of the machine: “Field voltage” must be provided.
 - Speed
The operated speed of the machine to be used in the short circuit test.
 - Short circuit instantThe short circuit instant can cause different behavior of the short circuit transient curve. It can be chosen among a list of choice:
- Instant 0: the linkage flux of the first phase winding is supposed to be maximum
 - Instant 1/4: the linkage flux of the first phase winding is supposed to be zero
 - Instant 1/2: the linkage flux of the first phase winding is supposed to be minus maximum
 - Instant 3/4: the linkage flux of the first phase winding is supposed to be zero
| Short circuit instant illustration |
Advanced inputs
The list of advanced inputs dedicated to this export are listed below.
Number of computations per electrical period
The default value is equal to 50. The minimum allowed value is 13.
Number of electric periods in open circuit
The default value is equal to 1. The minimum allowed value is 0.
Number of electric periods in short circuit
The default value is equal to 2. The minimum allowed value is 1.
Rotor initial position
By default, the “Rotor initial position” is set to “Auto”.
Mesh order
The default level is second order mesh.
Airgap mesh coefficient
