Magnet data
How to manage magnet parameters ?
Here is the list of user parameters related to the magnetic behavior of magnets.
| Label | Definition |
| T REF | Reference temperature. |
| Br at T REF | Remanent induction at T REF. |
| α | Reverse temperature coefficient for Br. |
| μ r | Relative permeability. |
| HcJ | Intrinsic coercivity at T REF. |
| β | Reverse temperature coefficient for HcJ. |
| (B.H) max | Energy product. Disabled input field, value deduced from other inputs. |
| Hcb | Normal coercivity at T REF. Disabled input field, value deduced from other inputs. |
| * | Maximum operating temperature. Just for information, not used in computations. |
| * | Curie temperature. Just for information, not used in computations. |
| 1 | Category dedicated to magnetic properties. Note: Magnetic properties are linked to the data
set in the “Operating Conditions” (See item 10 for
“Operating”). |
| 2 | Input parameters are written in the input area. |
| 3 | Remanent flux density (Br). |
| 4 | Normal coercivity (Hcb). |
| 5 | B(H) curve for the magnet (in blue). |
| 6 | Intrinsic coercivity (HcJ). |
| 7 | Isoline (B.H) max. (in red). |
| 8 | Load line for the defined permeance coefficient (in green). |
| 9 | Operating point for the given permeance coefficient and temperature. |
| 10 |
Temperature and permeance coefficient of the magnetic circuit are
defined as “operating conditions” of the magnets. These can be
edited in the dedicated tab “Operating”. Any changes will
automatically update the output.
Note: These features have no influence on the magnet’s physical
properties, but these are useful to display its behavior
when working at this operating point. |
