View general information such as the name of the file or folder, creation date, size, type, last modified date and
time, as well as who made the last modification.
The Analysis Explorer enables you to visualize results for model files containing simulation data for results, load
cases and result types. You can customize legends for color and precision, show and hide contours and add callouts
to the model for effective analysis and visualization.
Use the Hotspot Finder tool to find critical regions of your model based on a plotted result, filter the entities
based on selection set, threshold values, minimum separation, and load cases.
Build specific search for a file type, combine multiple search values by selecting correct operators (=, Like, or
Is) and values (file name, file extension, metadata).
View the files or folders that are shared by other users.
You can modify files or folders that are shared with you based on permissions
provided to you.
To view the items shared to you:
Click from your Favorite Apps on the home
page.
The Files tab is displayed.
Click Shared on the left pane.
The list also provides information about when a file or folder was shared and
who shared it.
Figure 1. Shared With Me
Alternatively, you can navigate to your folder and click the
SharedWithMe directory to view the shared files. A
list of user folders who have shared the files or folders with you are
displayed.
Tip: Click
to filter the list of shared files by a user name.
