View general information such as the name of the file or folder, creation date, size, type, last modified date and
time, as well as who made the last modification.
The Analysis Explorer enables you to visualize results for model files containing simulation data for results, load
cases and result types. You can customize legends for color and precision, show and hide contours and add callouts
to the model for effective analysis and visualization.
Use the Hotspot Finder tool to find critical regions of your model based on a plotted result, filter the entities
based on selection set, threshold values, minimum separation, and load cases.
Build specific search for a file type, combine multiple search values by selecting correct operators (=, Like, or
Is) and values (file name, file extension, metadata).
View the files or folders that are shared to other users.
The modifications and updates made to your shared file will be available for you
automatically. That includes access to the added comments, scenes, and specification
files.
To view the items shared by you:
Click from your Favorite Apps on the home
page.
The Files tab is displayed.
Click Shared on the left pane.
By default the Shared With Me list of items is
displayed.
Click Shared By Me.
The list of items shared by you is displayed. The last modified time and
modified by information is displayed.Figure 1. Shared By Me
