View general information such as the name of the file or folder, creation date, size, type, last modified date and
time, as well as who made the last modification.
The Analysis Explorer enables you to visualize results for model files containing simulation data for results, load
cases and result types. You can customize legends for color and precision, show and hide contours and add callouts
to the model for effective analysis and visualization.
Use the Hotspot Finder tool to find critical regions of your model based on a plotted result, filter the entities
based on selection set, threshold values, minimum separation, and load cases.
Build specific search for a file type, combine multiple search values by selecting correct operators (=, Like, or
Is) and values (file name, file extension, metadata).
result, filter the entities based on selection set, threshold values, minimum separation,
and load cases.
Modify and calculate hotspots for different result parameters. You can discuss the
hotspots with the shared members to analyze the model results.
Open a model file and expand the 3D viewer.
Click Show/Hide Browser .
Figure 1. Show/Hide Browser
The Browser window displays the model parts of a
3D model. Figure 2. Browser
Click Hotspots .
Figure 3. Hotspots
The Hotspot pane and the Analysis Explorer window are
displayed. Figure 4. Hotspot pane and Analysis Explorer window
In the Analysis Explorer select the required simulation
result, Run, Loadcase, and
Result Type to calculate hotspots,.
Figure 5. Select Simulation Result
Click Calculate in the hotspots pane.
The Calculate Hotspots window displays the chosen
Result Details. Figure 6. Selected Result for finding Hotspots
Enter a Name for the hotspot.
The Result Details displays, the active contour selected in the
Analysis Explorer.
Define Parameters to calculate hotspots for the selected result
details.
Result Value Filter is a predefined filter for calculating
hotspots on the selected contour.
Threshold is a contour value to calculate hotspots.
Hotspot Separation is the distance or tolerance between the
hotspots.
Number of Hotspots is the top number of hotspots to be
calculated at the specified position of a model.
Click Run to calculate hotspots for the selected results and the
specified parameters.
A list of model parts with the hotspot value is displayed in the browser
pane and on the model. Figure 7. Hotspots
Use the arrow keys to view the hotspot values occurred on each
part.
Figure 8. Hotspot on a Part
To recalculate hotspots, click > Edit to modify Parameters and click
Run.
