View general information such as the name of the file or folder, creation date, size, type, last modified date and
time, as well as who made the last modification.
The Analysis Explorer enables you to visualize results for model files containing simulation data for results, load
cases and result types. You can customize legends for color and precision, show and hide contours and add callouts
to the model for effective analysis and visualization.
Use the Hotspot Finder tool to find critical regions of your model based on a plotted result, filter the entities
based on selection set, threshold values, minimum separation, and load cases.
Build specific search for a file type, combine multiple search values by selecting correct operators (=, Like, or
Is) and values (file name, file extension, metadata).
type, last modified date and time, as well as who made the last modification.
To view and analyze the model files, you must run a job using the solver or
generate preview.
Choose one of the following from the home page:
Click from your Favorite Apps on
the home page.
Click .
Note: By default, the most recent files are
displayed, therefore this step may be unnecessary.
Click the Recent tab to view files that you have
recently accessed.
Note: By default, this tab is displayed, therefore this
Click the Shared with me tab to view files that
another user has recently shared with you.
Click the File or Folder.
The Files tab is displayed. Figure 1. Files Tab
Choose one of the following options:
Hover over a file or folder, click .
Select the file or folder and click Info on the
Action Ribbon.
Figure 2. File Action Ribbon
Right-click the file or folder, click Info from
the context menu.
Double-click the file or folder.
A window opens to the right of the
file.
By default, the Info tab displays the general information of
the selected file or folder.
