View general information such as the name of the file or folder, creation date, size, type, last modified date and
time, as well as who made the last modification.
The Analysis Explorer enables you to visualize results for model files containing simulation data for results, load
cases and result types. You can customize legends for color and precision, show and hide contours and add callouts
to the model for effective analysis and visualization.
Use the Hotspot Finder tool to find critical regions of your model based on a plotted result, filter the entities
based on selection set, threshold values, minimum separation, and load cases.
Build specific search for a file type, combine multiple search values by selecting correct operators (=, Like, or
Is) and values (file name, file extension, metadata).
View files and folders that you have recently accessed or files that have been
recently shared with you.
View General Information about a File or Folder
View general information such as the name of the file or folder, creation date, size, type, last modified date and time, as well as who made the last modification.
View the File Contents in 3D
You have an option to view your generated preview of your model file in 3d format and read its details.
Visualize Simulation Results Using the Analysis Explorer
The Analysis Explorer enables you to visualize results for model files containing simulation data for results, load cases and result types. You can customize legends for color and precision, show and hide contours and add callouts to the model for effective analysis and visualization.
Hotspot Finder
Use the Hotspot Finder tool to find critical regions of your model based on a plotted result, filter the entities based on selection set, threshold values, minimum separation, and load cases.
Add a Section Cut
Prepare a specification file to view the section cuts of a model using Section Explorer.
