Workflow
The typical workflow has four steps.
  1. Preprocessing: Simulation results (or test data) that are intended to be used for training might require preprocessing (e.g., filtering). This is an optional step.
  2. Training: Given a certain dataset, inputs, outputs, and state variables (plus possible physical constraints) are defined and the ROM is trained with a chosen architecture and some specified training parameters.
  3. Evaluation: The ROM is trained, and its accuracy requires verification. Some plots and visualizations (hyperplanes, loss vs epochs, preliminary time simulation) can be leveraged in this step.
  4. Deployment: If the accuracy check is successful, the ROM is ready to be deployed in a system integration platform.
