Batch Execution
The simulation and evaluation of a romAI model can be also done via batch in the Compose OML editor without the need to deploy the trained romAI model into a Twin Activate block, using the romAI_execute function.
The function is particularly useful when you want to access the results of a romAI simulation using a script.
[x, inputData, outputData] = romAI_execute(dataset_file, romAI_folder)
- dataset_file
- A string specifying the full path of the dataset .CSV or .MAT file containing the inputs on which the model is going to be evaluated.
- romAI_folder
- A string specifying the folder to save the romAI models.
Outputs
- x
- A vector of time or instances depending on whether the model is dynamic or static.
- inputData
- A matrix of inputs to the romAI model.
- outputData
- A matrix of outputs of the romAI model.
Examples
A practical example on how to call the function is shown below.
%Define dataset full path
dataset_file = fullfile(romAIdirector_dir(),'demos','romAI','linear',...
'mkclinear','TrainingDataset.csv');
%Define trained romAI model folder
romAI_folder = fullfile(romAIdirector_dir(),'demos','romAI','linear',...
'mkclinear','mkc_linear');
[x, inputData, outputData] = romAI_execute(dataset_file , romAI_folder);
