- Introduction
romAI is an application that is comprised of libraries from the Altair Composeand Altair Twin Activate software products.
- Design Fundamentals
romAI serves two purposes.
- Theoretical Framework
Some system theory terminology must be understood.
- ROM Framework
- Workflow
The typical workflow has four steps.
- Installation
The romAI tool is enabled through Extension Manager.
- GUI
The first steps of the workflow are accomplished through the GUI.
- Pre-Processor Tab
The Pre-Processor tab contains the optional pre-processing step.
- Builder Tab
The Builder tab facilitates the training step.
- Post-Processor Tab
The Post-Processor tab lets you visualize and evaluate the trained ROM.
- ROM Generation Tips
- Batch Training
The training procedure can be carried over without using the GUI.
- Batch Execution
The simulation and evaluation of a romAI model can be also done via batch in the Compose OML editor without the need to deploy the trained romAI model into a Twin Activate block, using the romAI_execute function.
- romAI Block
After you install the romAI library in Twin Activate, a new palette appears in the Palette Browser.
- Examples
- Frequently Asked Questions
