- Set Simulation Parameters
Before executing a simulation, you can define parameters for simulation time, zero-crossing and solvers.
- Create a Results File
Capture and review simulation results including the signals of all blocks in a model.
- Run a Simulation
Execute a simulation with the Run tool on the ribbon.
- View Results
Discover options to review, display, and export results.
- Troubleshoot
Learn troubleshooting techniques for common simulation issues.
- Debugger
The Twin Activate debugger is an interface that lets you control the advancement of a simulation so that, at every pause, you can inspect and modify block objects, which includes model signals.
- Functional Mock-Up Interface Support
The Functional Mock-Up Interface (FMI) is an emerging standard for creating interfaces between different tools.
- Simulation Phases
The process of simulating a model occurs in three phases: Evaluation, Compilation and Simulation. The Evaluation and Compilation phases occur first and generate a structure that is processed during the Simulation phase.
- Optimization and Linearization
Learn about the methods to optimize and linearize models.
- OML Editor
The OML editor is used to create, edit, and execute OML scripts.
- Python Editor
The Python editor is used to create, edit, and execute Python scripts.
- Spice Netlist
Spice Netlist lets you create a spice netlist of all spice components of the current model.
