Attention:Available only with Twin Activate commercial edition.
Twin Activate and Flux provide a powerful solution for modeling
and co-simulating electromechanical systems such as rotating machines, transformers and
many other complex devices.
Flux simulation software is especially suited to capture the complexity of
electromechanical equipment and optimize performance, efficiency, dimensions, and cost
or weight with precision. Flux also enables the simulation of magneto static,
steady-state and transient conditions, along with electrical and thermal properties.
Figure 1. Model of a Surface Mounted Permanent Magnet Motor
