This page lists default shortcuts.
Dock Windows
| To open |
Press |
| Command History |
Ctrl + Alt + H |
| Demo Browser |
F7 |
| File Browser |
Ctrl + Alt + F |
| Compose OML Command Window |
F8 |
| Compose OML
Variable Browser |
Ctrl + Alt + R |
| Project Browser |
Ctrl + F2 |
| Property Editor |
F3 |
| Python Window |
F4 |
Edit
| To do this |
Press |
| Copy |
Ctrl + C |
| Cut |
Ctrl + X |
| Delete |
Delete |
| Duplicate |
Ctrl + D |
| Paste |
Ctrl + V |
| Redo |
Ctrl + Y |
| Rename |
F2 |
| Switch |
Ctrl + T |
| Undo |
Ctrl + Z |
Edit Blocks
| To do this |
Press |
| Auto Mask |
Ctrl + M |
| Expand Super Block |
Ctrl + Alt + X |
| Flip |
Ctrl + F |
| Horizontal |
Ctrl + Shift + H |
| Remove Mask |
Ctrl + U |
| Restore Mask |
Ctrl + Shift + M |
| Rotate Left |
Ctrl + Shift + R |
| Rotate Right |
Ctrl + R |
| Show Name |
Ctrl + Shift + L |
| Super Block |
Ctrl + B |
| Vertical |
Ctrl + Shift + V |
File
| To do this |
Press |
| Close |
Ctrl + W |
| Close All |
Ctrl + Shift + W |
| New |
Ctrl + N |
| Open |
Ctrl + O |
| Save |
Ctrl + S |
| Save All |
Ctrl + Shift + S |
| Save As |
F12 |
| Save Selected |
Shift + F12 |
| Screen Capture |
Quick Snapshot |
Ctrl + P |
Help
| To open |
Press |
| Help |
Ctrl + F1 |
Misc
| To do this |
Press |
| Close All (Ignore Messages) |
Ctrl + Shift + F4 |
Scopes
| To do this |
Press |
| Hide All |
Shift + F3 |
| Show All |
Ctrl + Shift + F3 |
Simulate
| To do this |
Press |
| Model check |
Ctrl + Alt + C |
| Run |
Ctrl + E |
Tools
| To open |
Press |
| Diagram |
Ctrl + Alt + D |
| FMU |
Ctrl + Shift + E |
| Model |
Ctrl + Alt + M |
| OML |
Ctrl + H |
| Results |
Ctrl + Shift + D |
| Setup |
Ctrl + Alt + S |
View
| To view |
Press |
| Full Screen |
F11 |
| Maximize Window |
Alt + X |
| Open in New Window |
Ctrl + Alt + N |
| Restore Window |
Alt + Shift + X |
| Split Horizontal |
Ctrl + Alt + Z |
| Split Vertical |
Ctrl + Alt + V |
| Split Window |
Ctrl + Alt + W |
