Run a Simulation
Execute a simulation with the Run tool on the ribbon.
After define the parameters for your simulation setup and results, click
Run
The simulation starts and the Run tool changes to
Pause
. The green bar under the
Run tool indicates the progress of the simulation
versus the final time as defined in the Simulation
Parameters dialog. The actual simulation time is also displayed
in the lower left corner of the screen.
Pausing a Simulation
You can suspend a simulation in progress, make modifications to the model as needed, and then resume or restart the simulation.
While a simulation is in progress, from the ribbon, click
Pause
, or from the model, double-click a block.
The simulation stops. If double-clicking a block, a block dialog opens for you to change the block settings as needed. -
To resume a simulation, click Run
Depending on the nature of the modifications you make while a simulation is paused, the simulation either continues where it left off or restarts from the Initial time as defined in the Simulation Parameters.
