Add Property Information
Provide archival information for a model including a description and creator name.
From the ribbon, select the Model tool.
- From the Model dialog that opens, select the Properties tab.
Enter a description and an author or creator name for your model. For lengthy
descriptions, you can select the text editor, outlined in red in the following
figure, and enter your information:
