Search in Models
The Filter and Search tools help you locate objects in models.
The Palette Browser displays the diagrams and super blocks for a given model. By setting a filter, you can choose which objects are displayed and search for particular objects.
  1. To filter the objects contained in a model, click the Search objects tool, then click the Filtered menu:
  2. From the Entity Type dialog that appears, select the objects you want to display, then click OK.
  3. To find an object, select a search tool:
    Select this search toolFor this result
    All objects are displayed and the found objects are highlighted. To navigate through the objects, click the up or down arrows next to the search field.
    All found objects are displayed.
