Save or Export a File
Save a scene, a bundle, selected objects, a selected model, or a Studio set. You can change the autosave settings and turn on Safe save.
By default, models created in Inspire Studio are saved in the native format with the file extension .istudio.
When you save a file, you save not only its geometry, but also materials and display information, which includes views mode, zoom level, snaps, and grids status.
Tip: For better results when opening/importing and saving/exporting IGES or STEP files, it is recommended to select IGES/IGES PS-beta or STEP/STEP PS-beta instead of All Supported Files.
To Do this
Save the scene
  • Press Ctrl (Command) + S.
  • On the Files tool, click Save model.
  • Select File > Save.
Save as
  • Press Ctrl (Command) + Shift + S.
  • Select File > Save As.
Save an .iStudioPack
(Save textures, labels, and background images with your model)
  1. Do one of the following:
  2. For Save as type, select Inspire Studio Pack *.iStudioPack.
    The .iStudioPack is a compressed file that contains all of your textures, images, and labels associated with the original .iStudio file. This file pack is extracted to a new folder where all of your textures, models, etc, will land as well. Once the files are extracted, your scene will load.
Save selected objects
  • Press Shift + F12.
  • Select File > Save Selected.
Save a selected model to the Model Library
  1. Select File > Save Selected as Model.
  2. Under Preview type, select one of the following options:
    • Rendered: The Model Library shows a preview of the model as a rendered image.
    • Shaded: The Model Library shows a preview of the model in shaded mode.
  3. Enter a Package.
  4. (Optional) Enter a Category.
  5. Type a Name.
Save the Studio set
(Save only the lights and rendering environment of the scene)
  1. Select File > Save Studio Set.
  2. Enter a Package.
  3. (Optional) Enter a Category.
  4. Type a Name.
Change the autosave settings
  1. Select File > Preferences.
  2. Under the Category of General, confirm that Autosave is selected, and then type the Autosave interval (min).
Turn on Safe save
  2. Under the Category of General, in the Miscellaneous section, select Safe save.
